Hi there,
I had a new question come up regarding a project mentioned in a previous post.
I'm looking to install a generator setup at my in-law's. The goal is to power the main house panel and also the panel on the rental cottage on the property. The two houses are on two separate services from the electrical company.
I've worked out all the kinks regarding sizing of generator/circuits, voltage drop, etc. But the one question I can't wrap my mind around is: How do I split the neutral coming from the generator?
The initial generator switch box (with a 30 amp main breaker from the generator, and a double-pole breaker to each house panel) currently has 2 different neutrals coming in from the two respective houses. How would I wire this so that I’m not connecting the 2 different services’ neutral bus bars together? Because I’m aware that violates code. The generator feed only has one neutral coming from it - how do I split that to go to both houses? Or, if I can't, am I risking anything by having the rental cottage not connected to the generators' neutral? I believe both houses have shared neutral/ground bus bars.
TIA,
JC
TIA,
JC
