just put on a belt washed a couple of loads the belt breaks again, why?
Wrong belt, too tight, too loose, pullys out of allignment, bad bearing in pump, bad bearing in motor, bad pump, bad motor, bent motor shaft, bent pump shaft, loose motor mount, loose pump mount, loose drum mount broken drum mount, twisted chassis, or several combinations of the above.
Moon out of phase?Other than that what would cause it?
