Will not spin when fully loaded but if you put a small load in it spins fine. Suspect drive belt is loose ??
Thanks Chuck
Is it belt driven? Check drive block or dogs in the top of the agitator. Or, it may be a clutch problem.
Solid back cabinet? If so, most likely a direct drive motor. Check the motor coupling.
