The gas valve finally gave out on my empire rh-25-1 vented console heater.
It is older(maybe early 1990's, but has been used sparingly over the years, first in a cabin, and in my garage for the last five years. consequently, it is in pretty good shape other than the gas valve is kaput. I would like to repair the furnace rather than replace it.
Empire suggests i buy a robert shaw 700-204 valve(very expensive, exceeds the value of the furnace).
there must exist a valve that will be safe and appropriate for this heater, and relatively affordable. It is running on propane, has a standing pilot, a simple millivolt dial thermostat on board, and a flue limit switch. 1/2" in, 1/2" out. The plumbing supply houses wont give me any info other than" Empire lists this valve you have to use this one or throw the whole thing away" I understand their liability issues and don't blame them one bit.
If anyone could help me track down a new valve I would be very appreciative.
Thanks
John Klinkhammer
I found the valve in question here... http://www.supplyhouse.com/Robertsh...dS2bq8vzMQ0TnENvx_2YuckxmW-radz3Q7xoCoafw_wcB
I guess we need to determine your threshhold of pain when it comes to gas valve pricing. This one is a bit of a specialty in the way it works for that particular unit.
I am not too surprised by the price as most gas valves I have seen run in the $200-$400 range. There are some older universal replacements out there that can be had for $100-$150. It would be up to you to determine if you feel comfortable using one of these in place of a specific valve for your unit.
Thanks danpik, that's about 100 bucks less than the price i was getting from empire, but I am really looking for the "older universal replacements" that you mentioned. Where should I look and what am i looking for? Thanks much!
