The ignition system is obsolete and you may have issues getting parts.
You can rule out the gas valve by disconnecting the wire which opens the main valve. Could be some kind of intermittent short.
I doubt it - problem is likely upstream.
Need meter to troubleshoot it.
To be honest a unit with 3 wire pilot is not worth fixing - you'll be best off getting rid of it. I think they got rid of 3 wire pilot in the early 90s.
Heat exchanger likely cracked by now.
