my furnace has been acting fine since my last thread on it.
but now, its acting up again.
i am getting a code 4, ignition failure. the HSI is working fine, and inducer is running.
when it does not fire up, i shut the furnace off, work the knob on top of the gas valve. return power, then furnace starts up and runs normally, kinda. it runs fine, but it does not fire as quickly as it did. just now, the HSI just started to turn off, was still glowing though, then the burners ignited. the HSI used to stay lit for several seconds after ignition.
after the furnace started running normally, i could here a slight buzzing from the gas valve. i took a handy hammer and gave it some slight taps and the buzzing went away. coincidence perhaps.
what should i do ?
thanx
what should i do ?
thanx
