I am redoing the kitchen in my c1915 house. One of the main problems I'm having to contend with is how to vent a gas range. I'm holding off on my purchase until I get all the cabinets built and the room painted, etc., so my options are wide open at this point.
The problem is placing something above is out of the question. The range is in a box out with a shed roof and windows all around. That leaves me only with the options of pulling the air down and out or just staying with the old method of opening the window(s) surrounding the stove. Wife is not a fan of the Jen Aire's, she doesn't think the ovens are large enough due to the vent system. We had an older one in last house and my parents have a 4yr old one in their current house.
I've considered the pop-up style setups, but my reviews haven't brought up many positive reviews. They seem to be very loud and not very efficient at pulling out the fumes. The better ones are well over $1000 and that's tough to swallow on a, this might work, scenario.
I'm wondering if it would be possible to 'make' something. I actually have an old squirel cage, from old furnace, in a box I built, which I use to filter and suck air out of the house, when I'm creating dust. It has me wondering if I could just use something like that, as I believe some are variable speed, and just run some ducting up behind the stove along with a varaible switch. I have plenty of room in the crawl space under stove to place a fan. Another thought is to look for a good quality, scratch and dent fan, strip the components and use that minus the housing.
I'm curious has anyone ever done this, seen it done or have any suggestions? How high above the range should I place the vent if I attempt something like this?
I'll likely be using a 30" wide gas slide in range and I'm pulling this cabinet out 30" from the wall instead of the standard 24" due to a design detail, so I'll have about 6" behind the range for whatever I decide to do.
Thanks for any input and suggestions!
