I have a gas range (KUCHT Model KRG3618U – 36” Pro Class Kitchen Range), one of the burners when turned on to the ignite position starts sparking. It then lights, but continues to spark after being lit - and never stops regardless of flame position. It's only this one burner. I have done all the *easy* checks to determine the issue which include: cleaning the jets, checking for moisture, making sure the burners are seated correctly and all holes are clean.
So... After looking under the hood, I've come to understand there could a few other possibilities.
-There's the igniter and the lead that could be replaced - how could I verify that's the issue?
-There's a micro switch that get activated when the range knob is pushed in (MQS-216T). Could that go bad and how can I verify that?
-There's the 6 point spark module that could be replaced. How can I verify that? This is the expensive one, the cheapest one i found was $125. So i'd like to make sure that's broken before just replacing it.
THANKS!
THANKS!
