Did you pay your gas bill? Seriously, did you? If you don't have a notice od disconnection on your front and/or backdoor, check the merer cock on your meter- it should be straight up and down. Next, check all piping going to your oven. There should be a shutoff to your oven, so you may have to pull it out to ensure that it also still in the 'on' position.
#1 HAWKEYE FAN
not trying to be a smart ass but how would her shut off valves get turned off?
you most likely have a weak ignitor. It may glow but it has to draw so many amps before it will kick the gas on, when they get weak they will not draw enough amperage to this. Depending on your skill level it probably is not a diy task.
