I am trying to troubleshoot this problem; My furnace fan kicks on when the thermastat call for heat, its a hot surface igniter(ceramic plate that heats up) but the main gas valve won't open(most of the time), it was intermittent but now its about 90% of the time it won't ignite. Also when it does ignite it will run then turn off, but the fan will keep running then it will call for heat again and the blower kicks in and it will basically run all night if the gas does turn on?
So I think it is in the control box/panel but I am not sure what to troubleshoot in there as I don't know which control is for the main gas valve.
I checked the pressure switch, seems ok considering it lets the igniter engage.
I checked the flame sensor looks good, but it doesn't have anything to do until the main gas comes on correct?
ps the unit is about 20 years old and is a model;
Rheem "Imperial high efficiency"
