I just had the transite pipe removed from my house and I need to install a type B flue pipe from the furnace. There is a chase where the old heat pipe was and there should be plenty of room for the new type B pipe (1 inch clearance). I will be running horizontally for about 8' from the heater in the crawl space into an unconditioned laundry room. Then into the chase up through the first floor, then through the attic and out to the roof. How many firestops would I need in this case?
From what I read from Duravent and others is I will need one from the laundry room through the joists in the first floor into the chase and one as the pipe exits the roof. Do I need another perhaps at the top of the chase where the pipe enters the attic area? I just had a contractor here at the house and he had no idea what a firestop was! Thanks in advance for your help.
