I have a Carrier (Model 80U-19A) furnace from the mid-1970s that is not working. When the thermostat turns on, normally the flames ignite and a short time later the blower kicks in. However, the flames are not igniting, now. The blower still kicks in after the usual wait period. It is a simple two wire heat-only thermostat so I do not think the thermostat is the problem, since it is turning the blower on. The pilot is lit and the furnace valve knob is set to on.
There are no circuit boards/electronics. This thing is pretty basic. A simple panel, with wires linking 5 internal parts in various ways. They are: 1) a transformer-looking thing, 2) a fan and limit control (like this), 3) the gas valve, 4) the thermocouple, and 5) the blower motor.
Based on a test of an identical unit I know that the wires to the gas valve are supposed to send 24 volts when the main burner kicks on. However, on mine, this does not happen.
What is wrong with my furnace? I have a multimeter and can check things if you need more info.
I will reply on Monday.
Thanks!
Thanks!
