Put your wrench on the valve and another one on the nut next to it. You're going to push down on the nut to remove it from the valve. You will then have the option to cap off the valve end or buy new flex pipe and fitting for a new install.
No! Disreguard my like. Move over to the left one nut.
You can also remove the flare nut just to the right. But it's better to toss those and start fresh with new flex and fittings.
