Hello everyone,
I was hoping i could get some clarification if my boiler is operating correctly.
Background:
This issue only applies to the radiators zone:
So let's say i set the thermostat in the hall way to call for heat, I set it to a really high temp so that it forces the boiler to be constantly be on. The boiler will turn on, once it hits high limit of 170F, it turns off, cools down and fires back up. I understand this operation and it seems normal, however my issue is that these cycles are 2-3 minutes, so the boiler is constantly turning off and on, until room temperature is reached.
The tstat on the boiler only has a setting for a high limit, and I assume the differential for when it fires back up is hard coded.
My guess here, is that the boiler is heating up to high limit really fast, but also cooling down really fast, hence the on and off.
While looking at the temperature gauge during this operation, it warrants my assumption above, boiler fires up, temperature rises, hits limit, turns off, water temperature rapidly drops, boiler turns on.
The circulation pump for this zone has 3 speed settings. It was on the highest setting, changed it to speed setting number 2, this helped on the off time of the boiler as it was taking longer to cool down, however at this setting, the boiler heats up faster and shuts off faster then before.
Now this could be normal operation, just hate hearing the boiler turning on and off so much, and am not sure if it is impacting my gas bill in any way.
Any advice given is much appreciated.
Thanks
Background:
- 2 zones: Radiant heated floors in Kitchen + Stelrad Radiators on the rest of the house.
- HydroTherm Gas Fired Boiler
- Cold water Pressure at about 15psi. ( boiler in finished basement, 2 storeys high home ) At max operating heat of 170F, pressure at about 19-20psi.
- Tstat on boiler set a maximum heat of 170F.
Thanks
