I have a Utica Gas Boiler, Model number MCB125HD, with 3 zone heat. below picture shows the settings
I found yesterday that there was no heat at home. After checking, I found the boiler making humming sound,
the Taco Circulator pump is hot but touchable. All 3 zone pipes were cold. The Circulator pump was replaced and about one year old.
I turned down the temperatures on all 3 thermostats and waited some time (maybe 45-60 mins).
The Circulator pump is also cold by now. I then turned up the temperature in one zone to above room temperature,
and the boiler fired up and the pipe warmed up. I then turned on the temperatures for all other zones, everything
seemed back to normal, the boiler back to work and rooms warmed up.
This situation has happened a couple of times recently. Anyone knows what might be wrong? Thanks for any help in advance
