I have a 200 A service in my home. I ran and aerial run of #2 Quadruplex in between my house and garage (approx. 25 feet). From there I ran three # 2 copper feeders down on each side to the house panel and where the garage panel will be located.
Here is my question. I know I could have used my messenger/ground wire from the quad to go direct to the ground on these panels but they are two short. Can I just bug/splice another piece of # 2 aluminum or can I go with a smaller gauge copper. Also, should I through a grounding rod on this new panel as well while I'm at it? I have some # 8 copper on hand if that would be sufficient for that.
TIA - Brian
TIA - Brian
