I'm looking to add a storage loft in my double car garage over top of the garage door and door opener rails. The span is 20', and the shelf will be somewhere between 3 and 4' deep to the front face wall of the garage.
Question is, what is the best way to support this structure on the three sides where it touches the walls?
I'm envisioning a doubled up 20' beam across the span supported by threaded rod from the ceiling at a few locations along that span.
Where the beam attaches to the side walls, can I simply lag a 2x6 horizontally across a few wall studs and have the beam rest on that, or is it best to use a doubled up jack stud to rest the beam on? I'm guessing the jack stud is the best way to go, which is fine on one side of my garage, but on the other shared wall with my house, there's drywall ontop of plywood. Should I take the drywall/plywood down and do the jack stud?
Similarly, where the joists are supported on the front face of the wall, can I lag a 2x6 horizontally across the wall studs and rest the joists ontop (or use joist hangers), or can they rest on the header overtop of the garage doors?
Or am I really trying to overkill this support structure? Does anyone see an issue with the design in the picture I pulled from a website? If not, I may just keep it simple and do it that way.
Thanks!
Thanks!
