Hello all
I have a two-car (20'x20') attached garage with an attic above (no living space) and a single 16' garage door. It is fully dry walled and the ceiling will be flat white and the walls will be white (sheen to be determined later). I live in Northern Virginia so the average winter temperatures are not too cold but something to be considered.
Questions:
(1) Recessed or florescent lights? I never thought of recessed lighting until I did a search on in the forums here. What are the pro's and con's for each?
(2) My original plan was to put two four-foot dual tube T8 florescent in each bay (above the garage door) and three fixture perpendicular to the ones in each bay (see image below). There are already two incandescent hanging fixtures along with the lights from the garage door opener. The current lights are completely inadequate to have a workable workshop. Do you think the incandescent fixtures should stay for lighting on extremely cold days?
(3) Is there an "easy" way to have the garage door opener light a four foot florescent light? The current incandescent lights in the garage door opener are almost useless.
(4) Can the florescent layout be hooked to the existing incandescent 15amp (#14 AWG) circuit and not overload it? The current lights are wired to a three-way circuit.
Thank you,
Fred
Questions:
Thank you,
Fred
