My garage door has a weather seal but the rail to hold the weather seal does not extend all the way to the end of the garage door. At the end of the garage door is a metal box to hold the roller.
As you can see in the photo, there is a little light that shows through the bottom side of the garage door. Is there a way to cover that lit area. There is some air that passes by the garage door and enters the garage. I don't know if sealing that air gap would cause the garage to be any warmer in the winter. The garage door is aluminum so not much insulation due to the door. But drafts would be eliminated the better the seal is.
Is having the gap normal or should the weather strip extend all the way to the end of the garage door.
Thanks
Thanks
