Hi. My garage door has one of those hollow rubber seals that compress when the bottom of the door pushes down on the floor (as opposed to a straight, solid piece of rubber, like my old door used to have).
How tightly should that seal fit against the floor?
As it is, I can push my finger under the seal and run my finger along the full width of the door.
I wonder if the door should come down more, compressing the rubber completely against the floor. It seems like mice would be able to push their way past the rubber seal from the outside to the inside since I can do the same thing fairly easily with my finger. I don't see any daylight between the seal and floor, but still I wonder if it is not tight enough.
Thanks
Thanks
