First, I have 15" radius track, 6 1/2' door. 7 1/2' ceiling. I installed a pair of low headroom hinge which solved the headroom problem. I needed more for future insulating and drywall.
My question now is that I replaced the springs (pulley, rollers and cables). The wood door weighed 134 lbs on a bathroom scale. Knowing the scale is inaccurate and future repainting, I installed 150 lbs springs and the door is not settling to the floor.
When the new opener is installed, is this going to be a problem with the sensor that backs up the door when there is an obstruction?
If the answer is I should use closer weight springs, should I use slightly below 130 lb or 140? My reasoning was more weight springs would have been easier on the opener motor as well as a few times when I have to open it manually.
Thank you in advance.
