Another DIY Zombie
So, I am thinking of redoing the exit door on the back of our garage. The need is that I wanted to have a larger door in the back for moving items to the back yard easily (lawnmower, snowblower, etc.). Currently, it is an old wooden 32" door with a single pane of glass. At first I was going to leave the door and install a 5' garage door. But now I am thinking of either installing a 3' door, or installing a 32" double door (2, 32" double doors).
The problem I have is that I can not find a double door (think of french door with both sides operable).
Anyone have any ideas?
Framing Contractor
You can order these through any door supplier. If you can make the opening wider, a 3' double french door is easily available at most home centers. On most french doors, one side is considered the primary operating door.
I have a double french door on my garage. Bought it from Home Depot a few years ago for about $400 if I recall correctly. One side opens with the knob set, the other opens after retracting pins at the top and bottom. Functional and looks nice.
Another DIY Zombie
Discussion Starter #4
I like it
I do like the idea of the French Door for the garage, but I do not want all the glass. I am looking for something that is more like half glass half steel.
Going to keep looking looking though.
Thanks.
Super Moderator
Just go to a lumber yard (not a box store) and you can order a double door with any panel style you want.
