I would like to install a garage ceiling in my single car attached garage. Things appear a little tricky though.... The house is a ranch. I'm not familiar with all of the lingo, so bear with me here.
This is the basic framework of what I have now
This is the 2x6 support that runs sideways and sits on top of the exterior wall plate.
That 2x6 goes across the garage, through the wall...
This is the cavity above a staircase to the basement. The 2x6 continues through the next wall...
Where it sits on top of an interior wall plate.
Total length is maybe 15 feet.
Those long 2x6 supports that run the length of the garage are secured to the studs below the wall plates. There's only 2 of them.
Here's a look at the rafters and more supports.
OK, so what would be the best way to frame a ceiling here? Initially, I thought I could just run 2x6 every 16 inch OC from the wall (in the above pic) to the first support and then in between to the next support. Of course and also tie it in to the rafters.... Any help here is greatly appreciated!
edit: I do not plan on hanging drywall. I do not plan on putting a ton of weight up there. Just frame it out and plywood the top for storage.
