Doing a spring outside inspection on my 35 year old home I have noticed a continuous gap between my main floor brick and the flashing above which sits below and behind the second storey stucco.
Should I be sealing this with expansion foam,or other to eliminate a down draft behind the bricks, etc and stop the bugs from nesting and moisture seeping in.
To explain better I think I could reach in above the brick and wrap my fingers over the top the the wall behind.
