I recently had a new roof and gutters installed. The 1"x2" trim on the fascia was removed and the gutters installed. I inspected the work from inside the attic and there is a gap between the fascia and the roof deck (I can see daylight through the gaps). I also learned no metal drip plate was installed. Is there a fix other than taking down the gutters and resizing the fascia? Also can the metal drip plate be installed after the roof has been installed?
I am afraid of moisture damage and incorrect balance of air flow in the attic.
Thanks, for any help you can give me.
Dot
Dot
