Gable Vent Question
429 Views 5 Replies 4 Participants Last post by  Eddy66
Hi - Does it matter if a gable vent is off center? The truss's I built have a center support which will force me to put the vent on either side of the support. Does it matter ? Thank you
1 - 6 of 6 Posts
Other than esthetics you won't see any difference if the size is close to the same , but off center can be overcome with twin vents , one on either side of the support .
Reactions: 5
I would put it on the sunny side as it heats that side of the roof first and more.
I'm suspecting it would require a very accurate thermometer to determine any difference in attic air temperature at the same elevation anywhere in the attic .
I'd center it. What's your support a flat 2x4?
Hi Yes - it's a 2x4 with plywood gussets. Is that because of vent performance, or aesthetics, or both
Thank you
1 - 6 of 6 Posts
