I've just made a set of shelves for my friend's kid's room & she wants it painted red (we've chosen to go with Porter paint's Advantage 900 semi-gloss latex paint). I'd appreciate advice on how to finish the paint so that it looks and feels good (you know - the professional finish you get when you buy furniture).
I own a Graco Magnum X7 that I've previously used to paint my garage - but this is the first time I've tried it on furniture.
I have so far sprayed on a coat of Kilz acrylic primer & noticed the surface is less than smooth. It's not just that the Kilz raised the grain - it feels like the paint went on 'dappled' (kind of like the feel of an egg, or drywall - and not the smooth finish of well painted wood). So I went over the primer with a 220 grit dry sandpaper. That has helped some - but now the finish is somewhat uneven - a lighter gray where I've sanded & darker where I have not - and I don't want this to repeat when I paint the red. So I'm hesitant to proceed with the finish coats until I get some advice.
What is the best way to proceed?
Do I continue to sand between coats? ( I planned for two coats of the red) If so, should I use steel wool instead of sand paper?
Do I need to put a coat of wax over the paint when finished - or anything like that?
ETA - I'm using the 515 tip - should I go with a finer tip?
