Howdy all, my problem can not be all the difficult.
About 1 month ago the furnace would intermittently not turn on when the thermostat called for it. Sometimes it would. I toggled the Heat/off/Cool switch from heat to off and back to heat and the furnace would immediately kick on. I assumed the thermostat was faulty so I changed it and now we have to toggle the switch every time. The thermostat appears to be working correctly as it calls for heat when it should, it just wont trigger the furnace to come on. Toggle the switch and the furnace kicks on and off when it should.
Any and all help would be appreciated. We do have the furnace checked out annually and this years check-up showed no signs of any issues. Just trying to avoid a service call if the issue is simple.
Thank you.
Thank you.
