I have a 1987 Thermo pride hot air furnace. I have always had it serviced, last winter it started shutting off for no apparent reason. The serviceman came and could not find anything wrong. He did clean it and replaced the filter even though he had done this four months before. It continued to shut off every so often, I push the re-start button and it starts . Now after the blower stops there is quite a low bang in the duct work, I don't know if these two things are related. I would appreciate any advice anyone may have. I just lost my husband and can't afford a new furnace.
Sorry to hear about your husband. The low bang is probably the ductwork contracting after it cools down or deflating and making a bang. Nothing to worry about. I assume it is an oil furnace. You should NEVER press the reset button more than once as it may pump unburned oil into the chamber and that is dangerous. There is a reason the burner won't fire and all I can suggest is try a different repairman and maybe he will spot the problem. Perhaps one of your neighbors or friends can recommend someone they have good results with.There are about a dozen different reasons it may fail and some are fairly simple if the serviceman is experienced.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
