Left the fan in the "ON" position on the thermostat yesterday to help circulate air in the house and forgot about it- came home to find a loud humming noise from the boiler room, and no air movement at all.
Flipped the shut off switch and let it cool down a bit before trying again. Same thing happened when I turned it back on. Motor won't spin up to speed, makes loud humming noise. So here's what I've done to troubleshoot so far:
I can see it trying to turn as it hums, so I figured it was probably the capacitor. I took the cap out and brought it to a local shop to find a replacement. Replacement tries a little harder to turn, but still can't bring it up to speed.
So, if it isn't the cap, I thought maybe the motor had too much caked on dust and needed to be cleaned. I've only lived in this house for 3 years, but it was built in the 60s and who knows when the last time it was cleaned out is. I say this because I've never done it before so I was totally figuring it out as I go. Managed to remove the screws that hold the blower in place, pulled it out, and went at it with a vacuum and compressed air cans.
After putting it back in and flipping the switch, it *DID* power on and start spinning (fan in the ON position on thermostat)! But I shut it off and put the cage door back on, then flipped the switch to heat and lo and behold, it does not start. Just loud humming. I even put the fan "ON" again, and it did not start.
I thought maybe I need to add some oil? But I can't figure out where oil would go on this thing. The motor has an old barely legible sticker that says it has sealed bearings and does not need oil, so maybe that can't be it either?
After poking around and putting it all back together again, I flipped the switch on and I could hear it *trying*, but not starting. It seemed like it was getting close, so I shut the switch and waited 5-10 seconds, then tried it again. On the 3rd attempt at this, it spun up. At this point, I was afraid of losing it again so I just left the fan in "ON" and turned the heat on.
Once the house was up to the right temperature, I felt like I needed to shut it off. First of all, leaving the fan on 24/7 can't be the solution- this whole thing started when I left it on yesterday for a few hours instead of auto.
So at this point- It appears not to be the cap, I already tried to clean it, and the sealed motor design doesn't need oil. So what else could it be? Is the motor just dead? I feel like I see it trying to turn and sometimes it DOES spin up and just work, so what could it be?
