Hi all I have a payne furnace mode 490aav036060 serial#0996a23659. When I turn on the furnace all sounds normal until the hot serface ignighter try's to light nothing happens besides smell of gas. I replaced the hot serface ignighter with no change.
Yuri does it again! If you tap it and it works, it sounds like a bad connection, doesnt it Yuri?
Maybe that all importand ground screw is corroded? I would look at all solder joints with a Mag Glass and resolder any leads that look dull or like volcanoes.
