1 - 10 of 10 Posts
Hello all!
New here replacing our inducer fan on our goodman furnace. I bought a replacement fan off Amazon that replaces the current fan. Question is do I need the flue restrictor plate? The New fan only came with one gasket.. I have currently installed the new fan and it works perfect and no more clankety clank when the fan kicks on... Can I use some kind of high temp RTV to make a gasket if I need to keep the restrictor plate? Thank you for any advice!
Administrator
Yep, RTV works fine.
Administrator
If the old one had it, yes.
Administrator
Your welcome.
The restrictor plate gives it a higher vacuum. Your probably right on the edge without it.
Discussion Starter #7
Thanks for the information. I will clean up the plate and make a RTV gasket tomorrow I imagine it should be fine for a day
Administrator
Should be.
Administrator
Thanks for the update.
1 - 10 of 10 Posts
