1 - 7 of 7 Posts
:vs_worry: Definition of "On" & "Circulating" ??? Furnace Fan has 3 Settings (On, Auto, Circulating).. I had set the Furnace Fan to "On" to keep or thought to Keep the Air Moving.. Was told Fan should be set on "Circulating" ?? Thoughts Appreciated, Cheers Thanks
· Hvac Pro
Circulating can be a timed on system. Ie: 20 mins ON/40 mins OFF. That can be adjusted in the thermostat.
Need to read the furnace and thermostat manual. With Lennox ON is the lowest speed (40% of full) and is your continuos speed. However CIRC with HRVs and other units can be a timed ON feature like above.
:wink2: Yes it's a Lennox 2 Speed Fan.. Once the Burner Kicks In, Fan turns up..:glasses:
1 - 7 of 7 Posts
