Answer
Alright. So there are a few ways to find out. The easiest is to look at the furnace itself. If there is a white PVC pipe coming out of it to vent it you have a 90+ percenter. If it is shiny galvanized metal you have yourself an 80%. The next way which is actually more informative is to check the serial number (also labled as S/N inside furnace cabinet). It can tell you the date it was made, percent efficiency, and how many BTU your unit is. If you wanted to post it i can decode it for you.
