New Thermal Zone 2-stage furnace (apparently Rheem's budget label) that keeps cycling even when the T6 Pro thermostat is set at the same temp as the room (so theoretically no heat call). Cycle: 30-second inductor fan purge, 30-second low heat firing, then heat stops and the main fan runs for 90 seconds while giving a low pressure sensor error code; then the cycle starts all over again. Does this for 4 or 5 cycles then quits and status code goes back to "0". If the room temp drops, then the furnace responds by going to high stage until the call is met, but only after cycling 3-5 times as previously described. The installer has ordered a new control board but I'm curious if this is some sort of intelligent or comfort mode that we're not familiar with. Any ideas? Thx
