I just replaced the blower motor on an old Lennox forced air furnace and now the blower runs continuously while the burners cycles on and off. When the thermostat is satisfied, I can hear weird clicking noise, then I can hear burners shut off for several seconds. The clicking noise starts again and then the burners fire up. After a min or so the cycle starts again. The clicking sounds like an electrical shorting type noise. If I turn the thermostat down the blower will shut off but will not fire up again till I turn the thermostat up. There's 2 separate limit switches. One is a fixed limit switch and the other is a fan control. Would both of these switches be faulty? Any help would be appreciated. Attached are some pictures of the furnace, which is a Lennox.
The clicking seems to be coming from the gas valve looking component where the thin copper tubing is connected. The tubings are part of the flame sensors.
