Hi, I'll give a back story first. I have a 17 years old York Diamond 80 furnace. We RARELY use it so it's had an easy life (we live on coastal CA.). On Christmas we ran it for guests and it acted funny. Heated a couple of degrees shut off, blower stays on then heat fires up again. Tried the upstairs thermostat and it the furnace work fine (heat, blower worked for 15 minutes heated to right temp. shut off heat then blower shuts down in 2 minutes like it should. Maybe the thermostat downstairs is bad. put an old working thermostat on. Same issues. Maybe something in furnace. Opened up furnace to look around, now NOTHING works at all but the manual FAN setting on the upstairs and downstairs thermostats! I tried all the trouble shooting tips online to no avail. Also, the code light flashed 1 time for 1 second after the door is closed and then stays off. Any ideas?
Thanks. Kevin
Yes, dual zone and filter is new and vents open.
I have a York furnace that acts funny. The house is a dual zone (one furnace, two thermostats). The upstairs thermostat runs the furnace fine. Heats up fine, takes 5 minutes to satisfy the thermostat, heat stops then blower turns off in a minute or two.
Now, the downstairs thermostat, fires the furnace fine then heats for 3 to 8 minutes, flame/heat turns off then the blower run for 3-4 minutes. And the second the blower turns off the heat fires right back up again and does this for several cycles. There are no code flashes from the control board. What could cause this? Thanks!
Thanks. Kevin
