1 - 9 of 9 Posts
Hi guys, I have a Fujitsu Halcyon DC inverter in my basement that is not blowing hot air. The unit turns on and just blows cool/room temperature air despite it being on the heat setting.
Any suggestions on what to do? I did do a google search, but my filter is only lightly dirty (and wouldn't get in the way of blowing hot air anyways). I looked at the unit from the outside and other than looking a little rough from exposure to the elements, it looks fine.
What can I do at this point before bringing (and paying) someone to look at it?
Thank you for the help.
Oh then yes, the compressor is running. The system turns on and blows air. The issue is that the air is not coming out warm. It just blows out cool air when I want to heat up the room.
I don't know how to check the refrigerant charge.
Discussion Starter · #9 ·
Noted. It's never turned on anyways. I have some family visiting and they're sleeping in the basement so that's why I turned it on to see if the heat worked. I will be sure it's left off. Thanks again.
1 - 9 of 9 Posts
