1987 Nissan Stanza Wagon 4WD XE
Mitsubishi CA20(E) 4 Cyl 2.0L
fuel-injected
>200,000 miles
Starter cranks but engine does not ignite. It sounds and feels to me like it's getting flooded the more I try to crank it. Sometimes it does run if I'm lucky. The engine sounds really good when it does.
A fuel pressure gauge hooked up on the other side of the fuel filter from the pump and tank shows 37 psi after one pump cycle which is good. It drops to 36 quickly and then to 33 or so after a few minutes.
Spark plugs are one year old. I think the sparks plugs are firing because I pulled off a wire and it arcs to a ground nicely when I crank the starter.
An auto parts guy suspected the fuel pressure regulator. He said to check if there is any gasoline in the vacuum hose connected to it, but there is none. Part is $86-115.
I'm not sure about air. I assume it gets all the air it needs. I brushed off the air filter. It doesn't look too bad.
I not sure if a bad sensor could be causing this. I did check the coolant temperature sensor as a mechanic on Justanswer.com suggested. That seemed to check out ok. The male terminals on the sensor had 3.75 kOhms between them when cold, and the female connector had 5.04 volts DC supplied to it.
I would appreciate any help anyone can offer diagnosing this. I've been trying to get it running since I missed a first date with a girl when it wouldn't start in December. Thanks!
fuel-injected
>200,000 miles
