Left the hose on and the hose bib froze. Have access panel to plumbing PCV lines. Cant see how the metal end of the bib connects to the 1/2 inch PVC pipe. I have drilled out the mortar so the bib is loose in the brick outside, but am wondering if the hose bib threads onto the PVC pipe or is glued on? I could cut the PVC pipe inside the basment to pull it out but If the conection is threaded could I just unscrew it ? How do they normally connect Hose bibs to PVC pipe? If I can avod the gluing and cutting I would like to...
Thanks
Thanks
