Ayuh,.... So what's the Question,..??
Ya rip out the hydronic system, hang the new electric baseboards, wire 'em up, 'n hope yer electrical entrance is big enough to handle the added load...
Ayuh,.... So what's the Question,..??I already know of the pros, and cons on the conversion.
FHW is the BEST heating method available.Just looking to see if anyone around my area has done the conversion. I know it's not recommend for the colder parts of the country, or in larger homes.
I have never seen such a system, and I have asked if such a system ever existed. Never got an answer, and was always giving the $10+K options.FHW is the BEST heating method available.
Fuel oil appliances (to heat the water) and tanks are a major PITA.
If you're willing to spend a small wad... fix the actual problem:
http://www.heatersplus.com/products/boiler.html
(you may still have issues with amperage available)
I am on a budget for my electricity at $98 a month, and $395 for 100 gallons of heating oil last week. I liking the electric boiler option, since I wouldn't have to worry about a frozen line, or the sound of the system.So whats your electric rate, and what did you pay per gallon last delivery.
Electric baseboard may be cheaper to use then an electric boiler. Since with baseboard you can have a thermostat in every room, and only heat the rooms you want, and to a different temp in each room. unless you zone the baseboard system, using an electric boiler will still have you heating each room to the same temp.
Very true, but not dealing with a heater in the kitchen, and frozen line is we worth the extra $ a month.Short fills are charged a higher per gallon rate. your electric bill/statement still has the rate they charge you posted on it. Your electric bill will go up a lot after you switch to an electric boiler.
$35.27 for 1,000,000 BTUs deliver by oil at $3.95 a gallon. If your electric is under $0.12 per KWH all charges included, then electric will be cheaper. Of course, if you got 175 gallons per fill, the price of oil per gallon would be less.
