I installed a generator interlock on my garage GE load center, with a new 30A double breaker, 10-3w/g romex, to a Reliance 30A inlet box.
My generator is a Powermate BlackMax 5250/6560 that I've used once, and fire up every 6 months or so. I connected the generator's 20A receptable with a 20A cable, a 20A/30A adapter and 30A cable to the inlet box.
To test, I shut off the mains and all breakers, fired up the generator, flipped on the generator breaker and one circuit that controlled a few house lights and the light in the garage. The light in the garage went on, and everything was fine for 30-60 seconds. Then the generator coughed,the garage light went off and the generator started smoking.
After shutting down the generator, I noticed the wires were very warm right up to the load center. I took off the end of the generator and the windings on one side of the stator were burnt black. Also, plastic around the ground prong on the 20A cable had melted.
Any thoughts before I call a pro.
Thanks
Thanks
