Panel fell off, ribbon cable unplugged, took apart and plugged in, stuck on dispencing ice, light on also. Checked cable with ohm meter, looks like not broke anywhere, any ideas or thoughts on resetting procedure?
#1 HAWKEYE FAN
hooked back up wrong
How did you use ohm meter to measure voltage?? The voltage to the little moter is ac voltage and not measured by a ohm meter. I have been in repair for 50 yrs and know meter's. I bet the plug is plug in the wrong way unless it is made to plug in only one way like a bigger end or key way ?? check if it can be plug in the other way change and see if the motor turn's on with the little wire that hangs down?? the wire should be down for the motor to run and for water to flo. good luck
