I have a Kenmore Elite fridge 795.77554600 with freezer on bottom, a water dispenser on the door, and ice maker in the freezer.
Water line busted a year ago and too busy to fix until this lockdown. Water to fridge shut off all this time. Installed new water line and I bought a new water filter, but I got to thinking maybe I should be cleaning everything out with the lines to the dispenser and ice maker?
Saw an article on cleaning water lines: https://www.discountfilters.com/blog/refrigerator-filter-maintenance-clean-fridge-water-lines/
The article talks about using vinegar to clean line to water dispenser, which I understood. Another youtube video said to take water filter out and run water to the water dispenser. Can you do that with the water filter out?
With the ice maker, the directions in the link above were more confusing. How would you clean the line to ice make and the ice maker itself (I can clean the tray, talking about the ice maker). The article also talks about cleaning the reservoir too.
IF the article makes sense, can someone clarify how to clean the ice maker? If the article is overkill or wrong, I am all ears for a better way.
Just want to start using the water dispenser instead of buying all the plastic water bottles and have ice, but making sure it is clean water.
Thanks!
Thanks!
