Hi all. New to this forum, thanks in advance for any advice you can spare.
My home is on a rectangular city lot that has a negative grade from the street (about 6" lower at the back lot line). I'm blocked in on all sides by neighbors.
I get a lot of standing water in the backyard corner during and after storms and need a solution to drain that to the street. It's a 125-ft run from the back of the lot to the street. I don't know anything about drainage, and here's the options I'm considering:
Option A:Level the yard, then add a "sunken" french drain, discharging the water with an emitter
If I bring the yard to level, I've only got 6" of drop to use over 125 feet. (6" is the height of the curb at the street.) Not enough room for slope and not deep enough to bury pipe/gravel.
Instead, I'm thinking I can add a "sunken" system that terminates lower than the curb elevation, then use a 90-degree pop-up emitter to discharge the water.
I'd install about 20' of traditional perf pipe french drain in the backyard which would then connect to a solid run of pipe (~95ft) ending at the emitter. Trench floor would start at -9" underground and terminate –18" under the curb elevation. This yields a 1% slope, but the kicker is, water would need to travel vertically ~24" to exit through the emitter. Yep, the discharge is higher than the intake.
I never took a physics class so I have no idea if enough pressure can build at the back end of this system to force water out of the emitter?
This would be my preferred option since just leveling the yard would leave my house untouched.
Option B: Bring yard to level, then add a ~30ft stretch of 1% lot grade in backyard
In this option, the french drain would collect water at the base of the new grade, perpendicular to the lot, with a 1% slope. It then connects (L-shape) to a solid PVC pipe running lot-parallel for a mostly flat 95ft stretch, exiting through a curb cut. My concern here is whether there's enough pressure to push water through that long stretch of flat pipe.
Option C: Regrade the entire yard, front to back, incorporating a .25% slope.
I'm trying to add as little material as possible to my yard, in order to not bury my house in the process. This option doubles the height of the grade to 12" at the highest point in the backyard and gradually slopes down to 6" where it meets the curb, again a 125' run. Assuming a 4" diameter pipe, this give me about 5in of cover for the french drain in the back, which again would connect to a parallel solid pipe (L-shape) daylighting at the curb cut at 0" grade. Concern here is the very low % of slope.
Are any of these ideas viable, or is my approach completely wrong? Note that sump pumps are not an option.
Thanks a million in advance. Added an image with some diagrams if that helps.
