Hi folks,
I'm planning in install a french drain near the back of my house due to excessive moisture retention from a flat grading (clay soil). Unfortunately, regrading isn't ideal due to the presence of a retaining wall, so I'm thinking a french drain will be the best option alleviate the issue. My plan is to use 4" pipe surround by gravel and encased in landscape cloth. However, I have a few questions about this.
1) (It won't let me link the diagram, so I'll try with a reply to my own message) My initial thoughts are to go ahead and add three of the downspouts to this drain since currently the downspouts flow into buried corrugated pipes with no protection/landscape cloth/etc. and our land is full of trees which have obviously found the pipes. It's only a matter of time before they stop draining completely, so I want to add these into the drain I'm installing. My question centers around this: if I connect to the downspouts, would I still need a grade-level inlet near the "?" for proper flow, or would I get enough airflow from the downspouts to keep the water moving? My assumption is that as long as the drain (4" pipe) is operating at half capacity or less, flow should be fine, but I'm both unsure if that estimate is accurate or how often the drain will operate at that level.
2) If I do need an inlet, what is the best way to keep it clean so the pipes don't clog from dirt/debris/etc.?
3) As previously mentioned, my land full of trees, which have already eaten into the previously (poorly installed) downspout drains. Will landscape cloth wrapping the pipes and gravel be effective at keep out tree roots?
4) If tree roots are inevitable, I'm also considering using PVC pipe instead of slotted corrugated pipe so that I can clean out the drain in the future. However, given the extra cost (and effort to drill holes), I don't want to over-solve the problem if the corrugated pipe and other measures will effectively stay free of tree roots/etc.
Thanks!
Thanks!
