Can't use that formula for a freezer, the wetbulb is too low to be useful.
Is the cap tube is wrapped around the suction line to act as a desuperheater? If so, then you can't use the suction line temp after that point to determine charge level. Need to take it before that point.
You may be slightly low on charge yet. On a cap tube freezer, super heat should be about 10 degrees just after the freezer, or as soon as the suction line leaves the insulation of the box.
