I'm finishing up plans for a two level deck - the upper a 16'x20' two-beam ledgered to the house, and the lower a 16'x16' low elevation freestanding deck with a set of stairs joining the two.
I'm only planning on building the lower deck this year and the upper deck next year but I want to ensure that the lower deck is built properly to support the stairs between the two. Not sure yet if I'll get a permit for the lower deck as it isn't necessary but the upper will for sure.
Some info regarding the lower deck:
I have a couple of questions and hopefully someone can point me in the right direction:
Would like to hear what some of the experienced guys would do with this design.
Thanks in advance!
Mike
- Height of decking will be <=2'
- A couple of steps around the perimeter to get to the yard (not shown)
- Probably 2x10 construction. Blocking not yet shown
- No bracing added yet
- Potential room for beams if necessary
- The unframed area behind the hot tub will be a removable section for hot tub servicing
- Composite decking at 45 with a 2 board picture frame. Upper deck shows the framing/blocking that will be copied to the lower deck
- Is the double joist framing around the hot tub sufficient or is there a better way? I plan on making all outer joists double as well.
- What is the best way to frame to support the stairs? Only three joists are shown but not sure if this should be beefed up.
- I've seen low elevation decks with beams and without. My preference is to use beams but would this deck be better built without (ie frame it so it doesn't require beams)? I see using three beams - one on either side of the hot tub and one ~2' from the house
Thanks in advance!
Mike
