County inspector failed framing on my garage because the 7/16 OSB sheathing on 24" centers for the roof did not have plywood H-clips. He said an acceptable fix would be to install 2x4 blocking at all plywood seams.
This is fine, but it ruins my plan for insulating the roof with fiberglass, using the foam baffles to leave an air gap for ventilation from the soffit to the ridge vent. The main problem being that what would have been a 2" air gap, will now be reduced to 0.5" because of the installed blocking.
Are there any alternatives to the blocking that I could use? Perhaps something with steel that I could affix to the underside of the seams?
Thanks.
Thanks.
