I don't see why you need "floor joists" at 16" oc. I'd just put them at 24" oc, and use 7/16 OSB for "decking". Given the span and the fact that you are using 2x4's, this will only be suitable for light storage no matter what you do.
No. the floor joists would be 2x10. The back wall should be fine. But would like to see a picture of it.I may be using incorrect terminology by saying trusses, I am merely an electrician not fantastic on carpentry terms.
They are only supported by a 1x6
Are you suggesting an lvl across the center of the garage providing the front edge of the storage space? And then reframing the back wall with 2x10s?
We build anything that looks like a floor out out of 2x10s. For storage maybe 2x6, but I would go to 2x8 and 24" on center and 5/8 T&G plywood.Gotcha.
So say I took the back 10' and put up an lvl across the width, would I need a support beam to hold the lvl in the center? And are 2x10s necessary or would 2x6s provide sufficient support?
I would put the lvls as close as I could to the door tracks and then run the floor a couple feet passed the beam to get the extra deck.
Gotcha.
The people that sell LVLs can help with the engineering for the beam. Sometimes they go more and sometimes they go taller. You could go small with a center post, but then you have a center post and you need a footing and all that. You could check into steel beam to. If you do steel you want it drilled so you can bolt a flat 2x6 to the top of it.Okay, and the 2 ply lvl can span the 24' supported only on the ends? 10" width for the lvl I assume?
I will keep all of that in mind and look into it. I'm assuming this project might get bumped out a couple years to save up for the expense this will take. The wife will just have to be happy with basement storage and invest in a dehumidifier foThe people that sell LVLs can help with the engineering for the beam. Sometimes they go more and sometimes they go taller. You could go small with a center post, but then you have a center post and you need a footing and all that. You could check into steel beam to. If you do steel you want it drilled so you can bolt a flat 2x6 to the top of it.Okay, and the 2 ply lvl can span the 24' supported only on the ends? 10" width for the lvl I assume?
